CW LMS IPSec and SSH or... SNMPv3 for security?
Two questions?? IPSec and SSH, and SCP? or SNMPv3? to protect my SNMP etc. traffic? If the answer is IPSec then how do you set up the LMS/Windows 2003 server side of the tunnel?
Will the LMS SSH run inside of the tunnel? SCP? How big of a hit will I take on the CPU? How slow? Is DES56 being used for encryption on both? (Sorry, that's more than 2 questions) thx
Farrukh Haroon Fri, 06/13/2008 - 03:19
I would go for SNMPv3, it would be the easier to setup and manage. For the RME portion go for SSH, just make sure that SNMPv3 is supported on all desired applications (RME,DFM,HUM,CM etc.)
I don't think they all support V3 yet.
Farrukh
