sirdudesly Thu, 06/12/2008 - 22:45
what sort of budget were you looking at?
The most cost effective option (non including purely emulation) can be achveived on the 1700 series with serial WICs and then you can use a emulator to do the labs that can't be done on them (IS-IS is only supported on a couple of 1700 images I think and it's part of the BCSI roadmap)
Then 3 2950xl's for the switching components (so you can do STP etc)
Hi There
Have a look at this post on Wendell Odom's blog. Wendell is a CCIE who among other things writes study manuals for Cisco Press.
http://www.networkworld.com/community/node/27576
He recently went over what was required to set up a CCNP lab. He covered 3 budget levels and explained what part of the CCNP course was and was not covered by the different labs.
It is quite an informative article.
Best Regards,
Michael
rageurdreams Sun, 06/15/2008 - 05:45
Thanks for ur help...
I tried GNS3, but unable to go forward after installing it..
thanks,
dreams
