CM 6.0 installation problem
Jun 13th, 2008
Hello;
I'm trying to install CM 6.0 on a HP DL380-G4 Cisco compatible server. It passes the media check and starts disk and bios checks. But after that nothing happens. No error, no restart, no continue...
The last things i see are;
Machine passed harddisk checks
configuring 7835H-3400 machine
checking HP machine's BIOS version
RAID firmware version and configuration settings done
After these nothing happens. i waited for minutes and minutes but nothing changed.
Any idea?
jsivulka Thu, 06/19/2008 - 11:09
  • Bronze, 100 points or more
As I remember, there is a problem with remote upgrade in version 6.0, so you need to burn a dvd. Put the dvd in the local dvd-drive in the CUCM then it shoukd work.
m.graham@prime-... Sat, 03/21/2009 - 06:10
We encountered exactly the same problem and we were using the DVD. We waited for around 40 minutes and eventually it kicked into life and continued. I suggest a bit more patience will probably see you right.
