AAA/RADIUS
Farrukh Haroon Fri, 06/13/2008 - 02:50
When you logout and login back again, what error do you specifically see after you enter your credentials and hit the login button?
Also can you let me know your exact MARS version?
I know the configuration is pretty simple, but just try to compare your configurations with the following link:
http://www.cisco.com/public/news_training/itsnews/tech/chalktalk/200711.html
Farrukh
Farrukh Haroon Fri, 06/13/2008 - 11:35
Hello Ben, You could consider the following:
1) Clear the browser cache/cookies, if its happening on only one machine.
2) Have you considered upgrading to the latest release? I think they released v5.3.5 last week.
3) You could increase the logging level in MARS and then see what exactly is going wrong. However if you have TAC-Support I would go ahead and open a case, considering AAA support was just introduced one minor version before the release you are currently running.
Also are you using ACS or MS IAS?
Farrukh
