web/mail server issue
Jun 13th, 2008
Dear Sir,
I have a pair of 11501 and need to load balance a pair of web/mail servers. Below is the reloated configuration on one 11501.
interface e3
bridge vlan 30
interface e8
isc-port-one
!************************** CIRCUIT **************************
circuit VLAN10
ip address 10.106.13.250 255.255.255.192
ip virtual-router 10 priority 120 preempt
ip redundant-interface 10 10.106.13.249
ip redundant-vip 10 10.106.13.224
circuit VLAN30
ip address 10.106.13.18 255.255.255.248
ip virtual-router 30 priority 110
ip redundant-interface 30 10.106.13.17
!************************** SERVICE **************************
service PISWEBP01
redundant-index 31
ip address 10.106.13.20
active
service PISWEBP02
redundant-index 32
ip address 10.106.13.21
active
!*************************** OWNER ***************************
owner PIS_PISWEBP0102
content PIS-DNS-VIP-1
vip address 10.106.13.224
port 53
protocol tcp
redundant-index 35
add service PISWEBP01
add service PISWEBP02
active
content PIS-HTTP-VIP-1
port 80
protocol tcp
redundant-index 33
active
content PIS-SMTP-VIP-1
port 25
protocol tcp
redundant-index 34
active
Vlan10 is the external interface and web servers are connected to vlan 30.
We found that all none of the below works.
1. web
2. DNS lookup
3. SMTP
Any idea?
Thank you!
diro Fri, 06/13/2008 - 01:42
  • Bronze, 100 points or more
you are missing vlan 10 on an interface
josephschung Fri, 06/13/2008 - 02:20
Sorry, it is there as show below.
interface e1
bridge vlan 10
I missed it in the previous message.
Any idea?
Thanks.
jasmina27s Mon, 06/16/2008 - 09:08
1. What does the "show virtual-routers" command output says? Is the same CSS active for both virtual routers (front and back)?
2. Where do clients reside? Do you have a default route on CSS?
3. What does the "show service" command output says?
Best regards,
Jasmina
josephschung Wed, 06/18/2008 - 18:46
Hi Jasmina,
The information you need is attached.
e1 is the external interface.
e3 connect to a vlan for web servers.
Thanks a lot.
