CG224 - call disconection,
Jun 13th, 2008
hi,
I configured new vg224, but now i am facing one problem, user can make call with other extensions, if somobody picking the call on the first ring call is establishing, but voice is not happening, so if user pick the call after few rings no everything is working finaly
Can you please update me
sunish
irisrios Thu, 06/19/2008 - 11:20
Can you try removing caller-id enable, by entering "no caller-id enable" under the VG224 voice ports, and try a call.
Also refer to this bug CSCsi81450.
sunishnair Thu, 06/19/2008 - 21:24
Dear Irisrios,
Thanks for your replay, i also found the same issue only. When phone getting the caller ID after that communication is hapening correctly
sunish
