H.323 Loop
Jun 13th, 2008
  • Silver, 250 points or more
All I have a situation where the router is giving this in debug voip ccapi inout
001633: *Jun 13 08:19:34.467: %CALL_CONTROL-6-CALL_LOOP: The incoming call has a
global identfier already present in the list of currently handled calls. It is
being refused.
It is true it would look like a loop to the router, but basically I am sharing an ingress gateway with a vxml brower for CVP
so the call flow is ingress gateway, cvp, icm, cvp, gatekeeper, vxml gateway (same as ingress).
Is there a way to turn this loop batching feature off? any recommendations?
Thanks!
Chad
ebreniz Thu, 06/19/2008 - 11:15
this due to a check in IOS that produces (erroneously in my opinion):
%CALL_CONTROL-6-CALL_LOOP: The incoming call has a global identfier already present in the list of currently handled calls. It is being refused.
The misspelling is not mine either :)
The workaround is to configure "session protocol cisco" under the DP, and "allow-connections sip to h323" under "voice service". Note, I use an _ivs image for this, not sure if it would work without
