Catalyst 3560 Image Update changes memory figure to Zero
I have updated the IOS on a Catalyst 3560 switch from 12.2(25)SEB4 to 12.2(44)SE2. Prior to the upgrade the memory was shown as 118784K/12280K, but afterwards it shows as 0K/8184K. How can I correct this? I have copied the output of show version below.
Many thanks
Mark
show ver
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(44)SE2, RELEAS
E SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 01-May-08 12:16 by antonino
Image text-base: 0x00003000, data-base: 0x01400000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEA, RELEASE SOFTWAR
E (fc)
s3560-24_3 uptime is 12 hours, 3 minutes
System image file is "flash:c3560-ipbase-mz.122-44.SE2.bin"
cisco WS-C3560-24PS (PowerPC405) processor (revision N0) with 0K/8184K bytes of
memory.
Processor board ID CAT0936N1XJ
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:15:62:D6:79:00
Motherboard assembly number : 73-9673-06
Power supply part number : 341-0029-04
Motherboard serial number : CAT093614HC
Power supply serial number : DTH09328G7R
Model revision number : N0
Motherboard revision number : A0
Model number : WS-C3560-24PS-S
System serial number : CAT0936N1XJ
Top Assembly Part Number : 800-25861-03
Top Assembly Revision Number : B0
Version ID : V05
CLEI Code Number : COM1X00ARB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C3560-24PS 12.2(44)SE2 C3560-IPBASE-M
Configuration register is 0xF
gpulos Fri, 06/13/2008 - 02:25
  • Blue, 1500 points or more
Your configuration Register seems invalid.
Change it to a proper value. ie: 0x2102
(or 0x2142 if you need to ignore nvram)
Then reboot and verify the status.
If still a problem, post a 'show diag'.
Pravin Phadte Fri, 06/13/2008 - 03:18
  • Silver, 250 points or more
I dont feel its the problem with the Config Register.
The problem may be with the hardware.
Show diag would be helpful.
Also if you can reset the switch and check .
Pravin
joelau007 Fri, 06/20/2008 - 17:19
This is definately a software bug. My 3560 have the same error 0K/8184K when i went from 12.2(35) to 12.2(44).
