Optic parameters?
Jun 13th, 2008
hey all,
seems like a noob question but takes a long time with no answer ..., anyone knows where i can see the optic parameters of a SFP / GBIC on a cisco 6500 or 7200? i want to check Gain, loss, attenuation and other factors regarding optical interfaces.
regards,
Tom Randstrom Tue, 06/17/2008 - 18:15
  • Gold, 750 points or more
Some SFPs/GBICs support digital optical monitoring (DOM), per SFF-8472, which provides some optical power information (transceiver temperature, internally measured supply voltage, TX bias current, TX output power, received optical power, and two additional quantities to be defined in the future.).
The following document provides a Cisco compatibility matrix for Cisco SFP/GBICs, line cards, and software support.
Cisco Digital Optical Monitoring Compatibility Matrix
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_8031.html
I found this information regarding the IOS command to retrieve the DOM information stored in the memory.
“show interfaces transceiver”
To display information about the optical transceivers that have digital optical monitoring (DOM) enabled, use the show interfaces transceiver command in privileged EXEC mode.
http://www.cisco.com/en/US/docs/ios/interface/command/reference/ir_s4.html#wp1026864
I have not worked with this DOM feature, but I hope this helps.
