My MPLS Issue
Jun 13th, 2008
I have 4 7206vxr npe-400 routers in my network lab.
PE1<>P1<>P2<>PE2
PE1 and PE2 are running MBGP
I am running OSPF as the IGP protocol
If I connected all the routers using a serial back-to-back connection, the ip routing was working, but mpls was not! when I issue "show mpls ldp nei"...it failed!!
But, if I connect the routers using frame relay switch, everything work fine!!!
Can I know why?
n.nandrekar Fri, 06/13/2008 - 03:55
  • Silver, 250 points or more
hi!
When you are connecting back-to-back, using a serial, can you paste the interface config and the output of the command "sh mpls ldp discovery" ?
Also make sure that all the loopbacks are reachable through ospf?
Niranjan
