AXL query
Jun 13th, 2008
I have a problem, I want to display on my form the phone's description instead of the SEP address.
This is my code :
var phones = axlquery("listPhoneByDescription", "<searchString>%richard%</searchString>", callManager, callManagerUserId, callManagerPassword);
//var phones = axlquery("listPhoneByName", "<searchString>SEP%</searchString>", callManager, callManagerUserId, callManagerPassword);
var xmlDoc = new ActiveXObject("Msxml2.DOMDocument");
xmlDoc.loadXML(phones);
var objNodeList = xmlDoc.selectNodes("//name");
for (i=0; i<objNodeList.length; i++)
Response.Write("<option>"+objNodeList.item(i).text+"</option>");
I think that this line can be the problem but I'm not sure :
Somebody can help me?
Sascha Monteiro Sat, 06/14/2008 - 16:50
  • Silver, 250 points or more
hi,
I think the listPhoneByDescription only gives you the flexibility to search by description,
i.e. to filter.
As far is I could see in the axlapi schema, the return always has the same phone fields, name/product/model...
I think you have to do a executeSQLQuery and then retrieve name/description
(what is happening in the next step of your app?)
richou68000 Tue, 06/17/2008 - 23:21
After I need to find the IP address of the phone thanks to the "devicelistx.asp" in order to send a text message to a phone which is selected on a form.
Sascha Monteiro Thu, 06/19/2008 - 11:13
ok, so you can do what I advised in my previous post, use the description as text for the select item, and pass the name to your next step
richou68000 Thu, 06/19/2008 - 23:05
Have you an idea of how I can make this? I'm a novice with this method and I don't know how can I do this.
richou68000 Thu, 06/19/2008 - 23:44
Have you an idea of how I can make this? I'm a novic with this method.
stephan.steiner Fri, 06/20/2008 - 09:03
Well, let's try to help you help yourself then.
What do you understand about the APIs, and which commands do you think you need to use and why?
