WLC2106 access via my web browser doesn't work
Jun 13th, 2008
Pls can someone help. I cannot use my browser to access a wireless lan controller-2106 so i can complete configuration.
I have entered the initial configs at startup via console with the wizard.
I am running vista, i have made sure my PC is on the same subnet as the management IP. I can even ping the controller but when i ping my PC from the controller, it doesn't get through. I have also tried using windows XP. Or is GUI not possible on this platform?
Anyone help please.
Thank you.
richologbo Fri, 06/13/2008 - 03:14
Its ok now sorry, my mistake. I used a different port to connect to the device which is different from the management i/face port num i set initially.
