Cisco TSP 6.1 and IP Phone 7941
Jun 13th, 2008
I have the CUCMA 6.1 and I have installed on a server the Cisco TSP.exe version 6.1 in order to have the status info of the extensions.
It works very good.
I also hve these IP Phones:
- 7941
- 7961
At this point I would like, using the TSP functions, to send a Lamp ON/OFF command to the ip phones.
I saw that it is possible, but is there a "lamp ID" ?
I'm asking you this because I'm using a Tapi interface which permits me to program under Vb.Net environment and this interface(is a dll) permits me to send this command to the ip phone:
TapiPhoneSetLamp(DevID,LampID,Flash)
at this point my question is, where can I find the Lamp ID ?
Can you help me plese?
Thank you very much in advance!
chris.fortner Tue, 06/17/2008 - 10:06
16:05:41.625 CCM|StationD - stationOutputSetLamp stim: 9=Line
instance=1 lampMode=LampOn tcpHandle=0x4fbbc30
This is a trace of a lampOn request from callmanager to the IP phone. The tcpHandle is the IP address of the phone hashed! Hope this helps!
