06-13-2008 05:28 AM - edited 03-05-2019 11:36 PM
Hi all,
I need a bit of help getting a second vlan on my 878. I'm pretty sure it can be done, as we have another 878 with it working.
I can't add a vlan to the vlan database:
878-A#vlan 2
Vlan can not be added. Maximum number of 1 vlan(s) in the database.
878-A# sh vlans
No Virtual LANs configured.
878-A#sh run int vlan 2
interface Vlan2
description WAN OUTSIDE interface
ip address x.x.x.x 255.255.255.248
878-A#sh int vlan 2
Vlan2 is up, line protocol is down
Here's it working on another 878, even though it also shows no vlans:
878-B#sh vlans
878-B#sh int vlan2
interface Vlan2
878-B#sh int fa3
interface FastEthernet3
switchport access vlan 2
duplex full
speed 100
878-B#sh int vlan 2
Vlan2 is up, line protocol is up
Here's their versions:
878-A#sh ver
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(4)T7, RELEASE SOFTWARE (fc1)
878-B#sh ver
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(4)T8, RELEASE SOFTWARE (fc3)
Any ideas??? I'm really desperate to get this working!
Many thanks,
J
06-16-2008 12:44 AM
Hi J,
Can you try to upgrade your IOS.
In my router 878, i have :
Router#sh vlan-switch
VLAN Name Status Ports
1 default active Fa1, Fa2
10 data_vlan active
30 ITS_vlan active Fa0
999 mngt_vlan active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
I i try to make one more Vlan :
telane-bruss009(vlan)#vlan 111
Vlan can not be added. Maximum number of 4 vlan(s) in the database.
My IOS :
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(6)T8, RELEASE SOFTWARE (fc3)
Bye,
Khalil
06-17-2008 02:27 AM
Thank you for your response Khalil.
I will try upgrading to Adv IP Services. One question - how do I do this when flash is 2 small to hold existing and new image? I've not done this before...
Many thanks,
J
08-21-2009 06:02 AM
I had the same issue and i didn't want to upgrade the flash.
try:
c870-advipservicesk9-mz.123-8.YI2
Runs on the basic 878 (24MB Flash).
XXXXXXXXX#sh ver
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.3(8)YI2, RELEASE SOFTWARE (fc
1)
Synched to technology version 12.3(10.3)T2
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 14-Jun-05 18:58 by ealyon
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
ROM: Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.3(8)YI2, RELEASE SOFTWAR
E (fc1)
