CCNP Salary
Jun 13th, 2008
As I have only worked in the public sector, I don't have much knowledge about the salaries for cisco certified professionals in the the private sectors.
I currently have CCNA and a Masters Degree in Computer Science.
What type salary can I expect in the private sector if I get my CCNP combined with 5+ years of LAN/WAN experience?
Thanks in advance.
Overall Rating: 1 (1 ratings)
jim_berlow Fri, 06/13/2008 - 08:42
Wow - there are a lot of factors here. Things like what salaries are like in your area, the number and type of companies in your area, etc.
The fact that you have a Master's degree should help significantly and should help you command a much better salary than just having a CCNP.
So it is difficult to say here what your salary expectations should be without knowing more about you and where you are applying. However, there are a number of salary surveys out there that I recommend that you look at. Notably - look at certmag.com which publishes a yearly salary survey each December. You will need to look in the archives to find the last one, but that should give you a starting point for your area.
HTH,
Jim
sirdudesly Fri, 06/13/2008 - 17:48
Also depends where you live, here in Australia you see positions from about AU$65k all the way to about AU$130k advertised on job sites.
reazulhuq Mon, 06/16/2008 - 06:36
Thanks all for your reply. I am in Dallas, Texas.
I have looked into the survey and it's pretty good.
I was also hoping if some of you can share your personal experience on getting any salary increase after doing the CCNP.
Thanks.
joaquin48 Fri, 09/26/2008 - 06:39
I would say in texas you could probably make around 70 grand per year or more with a CCNP,
You just have to look well for the correct opportunity,
Good luck,
Joaquin
jim_berlow Wed, 10/01/2008 - 20:01
In the NW, a CCNP can expect between 90 and 115K. Granted housing is expensive on the west coast (which probably explains the discrepancy with the rates given in Texas).
I would start with those salary surveys and then adjust to your locale.
Good luck,
Jim
joaott1974 Fri, 03/30/2012 - 08:22
Impressive the difference between countries.
I have CCNP since 2005 and finishing my CCNP Security .In Portugal a good salary for  this certification is about 1500-2000€ /month .According to the legal employee law this means that a company needs to pay 14 salaries x 2000€ = 28.000€ / year .And there are a lot of people earning 500€/month in less specialized jobs.
Now all the people is going to say - "yea! ok but cost of life in Portugal is lower".But i dont think that much.
A common flat in Lisbon costs about 150.000€ - 200.000€ . A medium car about 20.000€ , 1 liter of milk 0.89€ , 1 liter petrol 1.74€ , and so on.
Thats why people complain , and specialized employees get out of this country.And mi really thinking about doing the same.
