Cisco Command
arunprasad78
What is the following command impact on router ?
ip telnet source-interface Loopback0
thanks
Arun
Harold Ritter
Arun,
This command makes sure that any outbound telnet sessions are sourced using the loopback interface address.
If you do not configure this command, the routing table is looked up and the address of the outgoing interface towards the destination address is used as the source address for the telnet session. The fact that the source address is not always the same might be an issue when building and ACL.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
HI Arun, [Pls RATE all Informative POST]
Refer useful link below:
http://www.ciscopress.com/articles/article.asp?p=27137
The document explains the usage of Loopback0 Interface as SOURCE for various Router Management Activities [Includes ip telnet source-interface Loopback0 - explanantion]
Hope I am Informative.
Best Regards,
Guru Prasad R
