UC500 outbound calls
Jun 13th, 2008
I am attempting to use a single analog pots line in an FXO port for outgoing calls. The line is currently working for incoming calls just fine. Is is possible for this to work? If I dial "9" all I get is unknown number and a busy tone. Thanks.
Overall Rating: 1 (1 ratings)
jbarcena Fri, 06/13/2008 - 07:26
As already noted seems to be a problem with your config. why don't you post the show run and we can go from there
acomiskey Fri, 06/13/2008 - 08:10
Thanks guys. I added "port 0/1/1" and have the following. It is now working outbound.
dial-peer voice 51 pots
corlist outgoing call-domestic
description ** FXO pots dial-peer **
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 5
destination-pattern 91[2-9]..[2-9]......
port 0/1/1
prefix 1
no sip-register
I have a lot to learn.
