Unity Web SA only works after reset
Jun 13th, 2008
I seem to be having an issue with IIS on my Unity Server. If I reset the server I can access the Web SA then after a day or so I can no longer access the SA and I have to reset the server again. It seems I have to reset IIS to get it to work. Anyone elese have this issue or heard of it?
Ginger Dillon Fri, 06/13/2008 - 09:19
  • Blue, 1500 points or more
Hi -
I know this was an ongoing problem for us, running Unity 4.2(1) until we applied ES52 and 56. You didn't mention your specific Unity version, so I would always recommend checking with TAC before applying on your own server, or at least test. Any ES applied requires a short Unity outage and I break the mirror set before applying these too. If you are running 4.2(1), I think the ES are available for download online.
Ginger
