How to setup toll-bypass with H.323 or SIP
danny.mclean
I am looking for an example or how to write this type of dial plan. I have exhausted many resources looking into how to write this. I have two UC500 tied together via a VPN and can make an intersite call using 71 or 72. I am trying to make a call from one through the others PSTN, to bypass the long distance toll. Any ideas??
6 Replies 6
Brandon Buffin
Here's an example of how to send calls to 7 digit numbers beginning with 555 across the WAN and out the PSTN interface of the remote router. Obviously, your IP addresses, phone numbers, codecs and ports may be different.
Local router:
dial-peer voice 1 voip
destination-pattern 9555....
session target ipv4:192.168.1.1
codec g711ulaw
Remote router:
voice service voip
incoming called-number 9555....
codec g711ulaw
dial-peer voice 2 pots
forward-digits 7
port 0/0/0
Hope this helps. If so, please rate the post.
Brandon
danny.mclean
Thank you for your response.
Is there a way to specify what area codes go to the secondary site, and the rest would go out the local site?
Thanks again
Sure. If you wanted to send calls to area code 202 to the remote router and all other long distance calls out local port 0/0, you could have:
Local router:
destination-pattern 91202.......
codec g711ulaw
destination-pattern 91{2-9]..[2-9]......
forward-digits 11
port 0/0
Remote router:
voice service voip
incoming called-number 91202.......
codec g711ulaw
forward-digits 11
port 0/0/0
Hope this helps.
Brandon
This is great. Thank you so much!!
Where you able to get this to work? I am trying to the same thing and the dial peer matches up, but the call is still sent out the local gateway.
I am working with one of our customers and have not had a chance to implement this. I will let you know once I get a chance to do this
