Security Wizard
Jun 13th, 2008
I think I blocked everyone on the network from accessing the Internet via port 80. I was using the Cisco Network Assistant and I thought I was blocking port 80 only for fa0/8. However, I think I ended up blocking port 80 on all ports instead! Now I am unable to reach the Cisco 3560 via the web interface or the Network Assistant!!!
Here is the code:
spanning-tree mode rapid-pvst
spanning-tree vlan 1,5 priority 0
vlan access-map SecWiz 10
action forward
match ip address SecWiz_Fa0_8_in_ip
vlan filter SecWiz vlan-list 1
vlan internal allocation policy ascending
interface Null0
no ip unreachables
How do I reverse this NOW!!!
jlcarey1usa Fri, 06/13/2008 - 08:48
I got it. You need to put "" around the name of the access-map. I was not using "" before. So for example, you need to type:
no vlan access-map "SecWiz"
