CUPC: # and * not working?
Jun 13th, 2008
We have an AVST CallXpress voicemail system and when we dial the number to access our mailbox, the # and * doesn't register as being pressed.
Has anyone ran into this issue with CUPC? Or is this an issue with CallXpress?
gogasca Fri, 06/13/2008 - 17:34
* and # works fine from my CUPC
Do you have an option in your server to see if DTMFs are being recieved? Like Port status monitor?
What type of integration is that one ? TSP-CTI, SCCP, SMDI?
craig.pollitt Mon, 09/15/2008 - 10:56
Sorry, I just saw your post...
I'm not sure that I can monitor that from the voicemail server itself. Would I be able to get that info from RTMT?
The integration is SCCP.
gogasca Mon, 09/15/2008 - 11:03
hi craig,
Yes, Please send us the detailed CCM SDI SDL trace for a bad call, include calling, called number and timestamps.
craig.pollitt Mon, 11/10/2008 - 06:03
To give the resolution to anyone that may be of interest:
The solution was to have "Require DTMF Reception" and "RFC2833 Disabled" settings enabled in CallManager for each AVST device and then reset each to have the changes take effect.
craig.pollitt Tue, 10/21/2008 - 05:47
Have you had a chance to look at those traces? If so, do you see anything glaring?
