CallManager CDR Log
Hi All,
Does anyone know if CDR log gets truncated after a successful BARS backup ?
I am running CCM 4.1.3 sr6a and I do have BARS schedule to run nightly but for some reason the CDR log does not get truncated and I have to manually shrink it atleast once a week to reduce the size.
Has anyone run into this issue ?
Is there a way to get the CDR log truncated nightly ?
Thank you very much !!!
Danny
gogasca Fri, 06/13/2008 - 10:06
  • Green, 3000 points or more
When you select CDR DB in BARS it should be truncated for backups
If it is not u can schedule a Job in SQL or a bat file and activate Schedule tasks service as workaround
