Wireless AP 1231 won't boot from the image!
Jun 13th, 2008
It gives a "error loading flash:imagename" error and goes to a default ap: prompt. The image on the system may be corrupt. How do I configure this ap to boot to another better image?
Thanks!
Scott Fella Fri, 06/13/2008 - 11:02
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Scott Fella Fri, 06/13/2008 - 13:22
  • Hall of Fame,
    2017 Wireless
is this a ios or lwapp ap?
misramanish Fri, 06/13/2008 - 14:18
was lwapp and has lwapp code in flash (c1200-rcvk9w8-mx). After setting the boot cmd to boot from flash to the lwapp code, it comes to a default (mac address) prompt. Is it now ready for lwapp or ready to be upgraded to IOS?
But the red light on the AP keeps on flashing meaning something is wrong?
Scott Fella Fri, 06/13/2008 - 14:21
  • Hall of Fame,
    2017 Wireless
That doesn't seem good..... What you should do is power down the ap and console into the ap also. Press the mode button down and plug the ap in and hold the mode button for 20 seconds. Release the mode button and post what the log shows.
misramanish Wed, 06/18/2008 - 13:59
I guess my requirements have changed a lil bit. So, if I need to make an autonomous AP become a LWAPP AP, is this what I do:
Make sure there is an IOS code in flash on the AP, then get the c1200-rcvk9w8-mx code through a tftp server and load it on the AP? Do I then keep or delete the IOS code? Check the MIC records and if there are any, I'm good?
Thx!
Scott Fella Wed, 06/18/2008 - 14:29
  • Hall of Fame,
    2017 Wireless
Follow this doc... it will give you enough info on how to upgrade from autonomous to lwapp.
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html
misramanish Wed, 06/18/2008 - 14:31
Thx, but the document refers to the upgrade tool and I am not able (or permitted) to use the tool. Is there no other way this can be accomplished manually?
misramanish Fri, 06/20/2008 - 13:50
I guess I need to rephrase my question:
To Lwapp a 1231 AP which is running IOS code 12.3(7) on it, should I just tftp the c1200-rcvk9w8-mx to it, and then set boot system flash to this new file?
Is that it?
Thx!
Scott Fella Fri, 06/20/2008 - 13:55
  • Hall of Fame,
    2017 Wireless
You need to download the Upgrade tool to convert the AP you have. TFTF will not work. Follow the readme file for instructions on how to upgrade.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
