Port/Traffic Monitoring Question
Jun 13th, 2008
I have a 3750G-24TS switch on version 12.2(25)SEE that I need to monitor traffic on.
I have tried using normal SPAN, but the server collecting the traffic also needs to have an active port to run other services, meaning SPAN doesn't appear to be a viable solution.
All the ports are local to the switch.
Can someone point me in the right direction for what I'm looking for?
Just to summarize, I need to:
- Have all traffic on specific ports (or a vlan) redirected/copied to a destination port used for logging.
- The destination port needs to be active for other services.
Thanks in advance,
Jeff
srue Fri, 06/13/2008 - 10:23
put another NIC in the server or use a dedicated sniffer.
