New Wireless Network...
Jun 13th, 2008
I have a small business about 20 PC's that I need to connect to a building that contains a group of computers on a sepearate network across a field, I would like to go wireless... I have a budget of inbetween $3000 & $4000. What equipment would you suggest that would get this taken care of for me???
Scott Fella Fri, 06/13/2008 - 13:56
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You would probably be okay with two ap's. look at the 1131 or the 1242. The 1132 has built in anetennas and can be mounted on the ceiling grid. The 1242 needs to have external antennas, which also can be mounted on the ceiling grid. If you need a connection between the two bridges, you can go with a 1400 bridge on both ends. Of course you will need hardware to mount the bridges on the roof and also you will need to cable from the bridge to the switch on both sides.
http://www.cisco.com/en/US/docs/wireless/bridge/1400/installation/guide/1400hig4.html
http://www.cisco.com/en/US/products/ps6087/index.html
http://www.cisco.com/en/US/products/ps6521/index.html
JGoodbrake Mon, 06/16/2008 - 08:13
I think I will be going with the 1400 Series Bridge... Thank you for the suggestions!
