CME Long distance not working
Jun 13th, 2008
I have a CME install with a PRI ISDN link for PSTN calls. Outbound long distance to numbers outside the local area code do not work, but dialing the full number (1+area code+local number) for local calls go through. I'm thinking this is a telco issue since the dial peer for outbound calls is a cut-n-paste from another CME router in a live working environment. Could there be something simple I'm missing?
Paolo Bevilacqua Sat, 06/14/2008 - 03:30
Hi, isn't like you are supposed to dial 1+10 anyway to outside of area code? Or explain. Posting config snipped would help understanding the issue too.
