Re: Cisco Call Manager 6.0 Phones not registered
Jun 13th, 2008
I have Call Manager .0 setup and the IP Phones are not registered. The Phones receive IP addresses, however when I try to ping the phones from Call Manager it times out. Does anyone know what could be the possible fix for this. NB The call Manager is on 192.168.130.1/27 network, the phones are on 192.168.65.0/24 and 192.168.66.0/24 networks. I am able to ping the Call Manager IP Address but not the phones
Jaime Valencia Fri, 06/13/2008 - 14:18
even if a phone is not registered but has the ip address config (DHCP or manual) it should reply to a ping
i'd check the routing in first place
javalenc
if this helps, please rate
m-laing Sat, 06/14/2008 - 06:55
I was also to resolve this problem, on the dhcp subnet I had put the wrong gateway for the voice vlan subnets. I changed it to the correct gateway and now the phones are registered.
thisisshanky Sat, 06/14/2008 - 10:00
Can you put a PC on the 192.168.130.x network and then try to ping the phones ? This may be a simple routing problem.
