thotsaphon Fri, 06/13/2008 - 13:03
  • Gold, 750 points or more
Miguel,
If you only want to use a fastethernet to be a wan interface then 851w is fine for home-use.Cisco 2620XM will provide you WIC slots and a network module.You can add any WAN interfaces in it but you have to separately purchase all of them.
Thot
miguelv06 Fri, 06/13/2008 - 13:28
for home use will i need any wic??? or module?? beside a switch module that has the 851w included...??
thotsaphon Fri, 06/13/2008 - 13:52
Miguel,
It depends on the media that ISP provides to you in your country. 851w provides you a fastethernet to be a wan interface. Just in case you want to change the media to be ADSL,Lease-Line then cisco 851w router will not give you to do that. Cisco 2620xm will do. That's why cisco 800 series give us many wan types.
Thot
miguelv06 Fri, 06/13/2008 - 13:55
i have a cable connection of 20Mb/s. with the company bright house they put a litle modem on my house that converts coaxial to ethernet =) hope this helps
thotsaphon Fri, 06/13/2008 - 13:59
Miguel,
If that's currently a wan interface type then cisco 851w is fine to be used.
Thanks for providing the important information
Thot
miguelv06 Fri, 06/13/2008 - 14:02
so in your opinion the 851 will be a better solution than a 2620xm? even though i has less memory?? is there any benefits buying the 2620xm for "home use"
pst: i have 2 servers inside my house...
