adding metric or weight to advertisements at the interface level
Answered Question
Jun 13th, 2008
Under the router rip command you can add an offset to a received route using the offset command and an ACL. Is there a command you can add to an interface so that all advertisements it sends are already modified with a weight or hop count or some type of offset?
Diego
Correct Answer by Jon Marshall about 8 years 8 months ago
Diego
Using the offset command under the "router rip" configuration there are optional paramneters to specify an interface. So if you want to offset routes received/sent on a a particular interface you can specify this in your offset list. See link for details:
http://www.cisco.com/en/US/docs/ios/12_2/iproute/command/reference/1rfrip.html#wp1017883
Does this answer your question ?
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Fri, 06/13/2008 - 13:44
Diego
Jon
DIEGO ALONSO Mon, 06/16/2008 - 04:31
Yes, thank you very much. Don't know what I hadn't seen the interface option. Maybe I was using an older IOS that doesn't support that.
Thanks again,
Diego
