Jun 13th, 2008
Hi, the AAA server which is used for accounting, autharization and authendication. As per accounting it stores the information "what user's did do?" then can the same imformation keep the syslog server?? Thanks.
michael.leblanc Fri, 06/13/2008 - 15:42
I'm aware of (but not familiar with):
router(config)#gw-accounting syslog
... which can be used to generate H.323 call start/stop CDRs (VoIP Call Detail Records).
or, if you were using the Authentication Proxy feature:
ip auth-proxy auth-proxy-audit
... but I'm, not aware of broad spectrum support for syslogging all Accounting records. If there is such support, I'll be interested to hear of it.
