CallManager 6 Personal Directory
Jaime Valencia Fri, 06/13/2008 - 15:57
unfortunately no, there are some threads on how to try to make the login automatically. you can look for personal directory or PAB within netpro using the search feature
if this helps, please rate
jessica1983 Fri, 06/27/2008 - 04:20
You only have to enter it once then it appears automatically anyway
