06-13-2008 02:09 PM - edited 03-03-2019 10:21 PM
Can you run Auto Qos on Multilink PPP or Frame-Relay MFR Multilink groups where you have multiple T1's bonded? Or would I have to setup QOS manually? This will be used to give priority to Cisco IP Phones.
06-13-2008 02:18 PM
Hi JIM,
Q. What interfaces currently support Cisco AutoQoS?
A. Router platforms: Cisco serial (PPP/HDLC), Frame Relay DLCIs and ATM VCs on the router platforms
Thot
06-13-2008 02:33 PM
That Still doesn't specifically answer whehter it is supported on Multilink PPP or Multilink Frame-Relay (MFR). It looks like I can add the Auto QOS commands under the DLCI's and the multiple physical interfaces for MultiLink PPP setup but not the multilink groups themselves. Is this the correct way to set this up?
10-08-2018 12:53 PM
10-08-2018 12:54 PM
When MLPoFR is configured, this IP address is removed and put on the MLP bundle. The AutoQoS—VoIP feature must also be configured on the ATM side of the network.
10-08-2018 12:55 PM
Just incase someone else is searching for this information. https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_auto/configuration/15-mt/qos-auto-15-mt-book/qos-auto-voip.html
