Questions and recommendation regarding 851W/871W models
Answered Question
Jun 13th, 2008
Hi there.
Basically I'm wondering what the best option would be from these two particular units. I'll write what I'm trying to achieve and I'm hoping somebody can point me in the right direction.
I require 2 wireless SSIDs to be broadcast, one for employees (encrypted [WPA2]) and one for public (unencrypted). From this I require two different DHCP scopes to be handed out to each of these and the ability to block traffic from crossing between the two different subnets.
I also require transparent proxy support (requests for HTTP from the public SSID are to be forwarded to a Squid proxy running on a different subnet) and finally 1-1 NAT support so internal addresses given by the DHCP server on the 'public' SSID are translated to addresses on the WAN subnet.
From what I've read and researched it seems that the 851W will perform all of these items however I'm slightly hazy on whether I'd require the 871W to actually broadcast the two different SSIDs.
Any help would be greatly appreciated! Thank you in advance.
Correct Answer by paolo bevilacqua about 9 years 1 week ago
Hi, I have not checked if policy routing is in all the images for the 871, possibly it is.
I never used multiple broadcast'd SSID and I'm not sure of what is doable with the 871.
A properly configured "internal" PC does not need brodcast to connected to the internal SSID/VLAN. Multiple broadcast SSID are more useful for service provider APs carrying multiple network choices for the customer.
Usually customers (wrongly) associate non-broadcast SSID to better security, while in thie case they want all to be broadcast ?
This is why I'm telling that you need to familiarize yourself with the product and possibly with the different image options, to understand what is possible to do and what is not. All proper designs are made like this.
Thanks for the appreciation and good luck!
Overall Rating: 5 (5 ratings)
paolo bevilacqua Sat, 06/14/2008 - 09:56
  • Hall of Fame,
    Founding Member
Hi, for this you need the 871w. The 851 doesn;t support multiple vlan and you have trouble with the multiple SSID that are in fact, mapped to VLANs. Note if you have ADSL is always better to get the 877 with ADSL interface so you can controle the circuit for real.
ian.kaney Sun, 06/15/2008 - 08:05
Thanks for the reply. I'm using a connection provided via Ethernet so I assume the 871W is the unit I require?
Will I require the advanced IP upgrade since from what I've read VLANs aren't supported with the default feature set?
ian.kaney Sun, 06/15/2008 - 14:44
Ok that's brilliant.
Can I just clarify that I would be able to setup a transparent proxy service utilizing a proxy server on the WAN subnet using this unit?
And finally, the product specs suggest that 'wireless VLANs' are indeed available on the unit with the base IOS image. Would these be sufficient for my requirements? The only connecting machines would be via wireless, the only wired connection would be to the 'WAN' port.
My other thought was that the 'employee' wireless SSID could get their IP from a DHCP scope on the WAN port which from what I read is on a different VLAN to the standard VLAN1 the ports use which the 'public' SSID users could connect to?
If that makes sense?
My apologies for all the questions but I want to be sure I get the right model before I spend the cash... Thank you so much once again.
paolo bevilacqua Sun, 06/15/2008 - 16:52
  • Hall of Fame,
    Founding Member
Hi, for transparent proxy you should look at the doc of what you're using, cisco support wccp that is a nice way to do it.
I think you need advance service exactly because you need vlans to map the SSID for internals to something like another dhcp server. You can try anyway with ip base first then upgrade as necessary. It also depepnds how you want the VPN, etc.
ian.kaney Mon, 06/16/2008 - 09:31
Thank you so much for your help.
I spoke to Cisco live chat and now I'm completely confused. They are now informing me the base 871W image doesn't support static NAT.
WCCP is only on the advanced ip services image and the extra functionality it provides would be lost in the environment I'm using anyway.
Would the 871W allow me to configure a transparent proxy such as (1.2.3.4 is the proxy server on the WAN side):
access-list 110 deny tcp host 1.2.3.4 any eq www
access-list 110 permit tcp any any eq www
route-map proxy-redir permit 10
match ip address 110
set ip next-hop 1.2.3.4
Thanks once again for this, I'm desperate to go ahead and purchase but the more I investigate, the more I'm getting confused with misinformation.
paolo bevilacqua Mon, 06/16/2008 - 09:39
  • Hall of Fame,
    Founding Member
Hi, the nat information you have received is wrong, basic nat is in all images.
The example you made is (incomplete) for what is called policy routing. If you have never worked with cisco before, suggest you do some testing first, for your applications.
As an appreciation for those providing answers, please rate useful posts!
ian.kaney Mon, 06/16/2008 - 09:42
Thanks for clearing that NAT issue up.
Yeah I was just showing the commands relating to the transparent proxy section, wondering whether these will indeed work on the 871W.
The Cisco person also stated that I can have 10 SSIDs all broadcasting in guest mode? Is this correct because other articles I've read state only 1 SSID is possible to be broadcast?
The 871W seems to allow 2 MBSSIDs though which from the reading of the Cisco site is what I require? 2 SSIDs broadcast (guest mode) which a user can connect to either.
Correct Answer
paolo bevilacqua Mon, 06/16/2008 - 09:48
  • Hall of Fame,
    Founding Member
