06-13-2008 04:56 PM - edited 03-05-2019 11:37 PM
I have a 3750 that I'm using as a router:
"ip routing"
..and "no switchport" on the routing interfaces.
I added "ip accounting output-packets"
on both the interfaces setup for routing and ran a bunch of traffic through the device. But "show ip accounting" gives me nothing.
This seemed to work so easily on my 2821 router. Is there something about this being a switch that messes with accounting? Is there an alternative? Thanks!
Solved! Go to Solution.
06-13-2008 05:04 PM
Sorry, ip accounting is not supported under Catalyst switches.
HTH,
__
Edison
Please rate helpful posts
06-13-2008 05:04 PM
HTH,
__
Edison
06-13-2008 05:06 PM
Thanks for the reply!
Too bad they can't remove unsupported commands.
