Problem booting up a Catalyst 6504E
Hi guys,
I am experiencing a problem with my Catalyst 6504E. When I power it up it always gives the following error
" Autoboot executing command: "boot bootflash:c6sup22-psv-mz.121-20.E3"
open(): Open Error = -9
loadprog: error - on file open
boot: cannot load "bootflash:c6sup22-psv-mz.121-20.E3"
When I try to manually boot it using the the boot command from rom monitor mode, it give the following message
*** System received a Software forced crash ***
signal= 0x17, code= 0x24, context= 0x42743de4
PC = 0x401299fc, Cause = 0x1020, Status Reg = 0x34018002
after the system decompresses the image.
I thought of a corrupted image and I tried downloading a new Image to the system using XMODEM many times but it keeps failing after reaching 45-50% of the transfer.
I want to delete the current image in bootflash: before
attempting to upload again but I don't know how can do that from ROMMOM>
I will apppreciate ur help
I am having the same issue on a 6509E /W Sup32.
The recovery procedure that uses slot0: (Compact Flash) does not work on any of the sup32's I have (3). The Xmodem procedure fails anywhere after 10% of the file transfer.
I've opened a TAC case and am awaiting action.
The possibility of not being able to recover a crashed Sup32 RP image is scarey.
Bill
