Diffrence between NM-1CE1T1-PRI= and VWIC2-1MFT-G703=
ajay chauhan
Level 7
Level 7
what is the function wise diffrence between both the cards for E1 link.
paolo bevilacqua
Hi, beside different generations, one is an NM the other a an HWIC. Both wold work foran E1 circuit. The g.703 variant is needed only if you have an unframed circuit and want to us it in full.
5 Replies 5
paolo bevilacqua
Hi Ajay,
In addition to what Paolo has mentioned, NM-1CE1T1-PRI module supports only DATA, no voice support on this module.
-> Sushil
Yes, and in fact the evolution of it is the new HWIC-1CE1T1-PRI that you may want to consider as well.
Hi guys, this HWIC-1CE1T1-PRI is supported in the Cisco 3825? It can be inserted in the HWIC slot without the need of a Network Module?
Thanks for making clear.
All the best
David
Yes, it can provided you have an IOS version with support for that.
