ATA186-Problem with second DN
Answered Question
Jun 14th, 2008
Dear sir
I wanted to know that how to configure 2 DN numbers on my ATA186. as i can easily configure single DN on my ATA and my port 1 of ATA show me dial tone, but when i try on port two it does not provide me dial tone , either port one works or port two work, becuase i can assign only one DN on my Call manager 6.0.
when i tired to assign 2nd DN i got error, i have attached the screenshot ,kindly correct it.
Correct Answer by Rob Huffman about 8 years 10 months ago
Hi Zeeshan,
Hope all is well :) This question has thrown us all at one time or another. The Second Line on an ATA is actually added as a completely seperate device just using a modification of the original mac address.
Use this procedure to add the second port on the Cisco ATA 186 to Cisco CallManager.
Drop the first two nibbles of the MAC address and shift the MAC address to the left, then add 01 to the right end of the MAC address. For example 00070EA26032 is port 1 and 070EA2603201 is port 2.
From this good albeit "older" doc :)
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_configuration_example09186a00800a892f.shtml#con4
Hope this helps!
Rob
Overall Rating: 5 (3 ratings)
Correct Answer
Rob Huffman Sat, 06/14/2008 - 15:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Zeeshan,
Hope this helps!
Rob
Rob Huffman Sun, 06/15/2008 - 08:11
  • Hall of Fame,
    Founding Member
Hi Zeeshan,
You are most welcome my friend :) Glad to be of some small help.
Take care,
Rob
hellspire69_2 Tue, 06/17/2008 - 05:37
Sorry to drag this one up again.. I also have the problem to add the second port, I have followed the documentation, but the CCM gives me the message that the mac address is already in use when I amend the mac and shift it too the left.. any ideas on this one guys :)
Rob Huffman Tue, 06/17/2008 - 05:48
  • Hall of Fame,
    Founding Member
Hey Dan,
Hopefully we can resolve this one :) Have you done a search in CCM>Device>Phone>Search by "Device name = specified mac address (070EA2603201 in the example below)" to see what is on the second port?
Hope this helps!
Rob
hellspire69_2 Tue, 06/17/2008 - 05:51
Yep and it comes up with just the one device:
1B53F0BF3B01 so for the second port i amended this too 53F0BF3B0101 ? I think im correct here if im following your methology... or hope so :) after i try to input this and click away from the mac address field is when i get the message saying that the mac address is already in use.. ta :)
Rob Huffman Tue, 06/17/2008 - 06:18
  • Hall of Fame,
    Founding Member
Hi Dan,
So if you do a search on Device Name = 1B53F0BF3B01 what does it show.
Same for 53F0BF3B0101 (it seems odd that this mac already ends in 01??)
Rob
greggmatias Tue, 06/17/2008 - 06:22
OUI for cisco is 001B53.
If i may guess your first port MAC should be 001B53F0BF3B. Then for the second port, should be 1B53F0BF3B01.
gregg matias
Rob Huffman Tue, 06/17/2008 - 06:28
  • Hall of Fame,
    Founding Member
Hi Dan,
I think what it looks like (perhaps) Is that you have something configured on Port 2 already and nothing on Port 1. Is this possible? Thus the mac addresses?
Rob
Ayodeji Okanlawon Tue, 07/08/2008 - 05:26
    2017 IP Telephony
Rob,
This really helped me. I was just wondering how to add a 2nd line for an ATA 186 and I found this.
I gave you a nice 5 point for this.
Hoep your holiday is going well..
Rob Huffman Thu, 07/10/2008 - 04:06
  • Hall of Fame,
    Founding Member
Hey Deji,
Thanks buddy! Holidays have been really great, fun times with friends and family. It's always great to get away from time to time :)
Take care Deji!
Rob
