which modules go in which slots in 6509E?
Jun 14th, 2008
It appears that in a 6509E there are 3 different backplane slots therefore certain modules can only go in certain slots. Is there a tool that will tell you which modules go in which slots? I have a SUP720, 10GE module, and FWSM.
Justin Brenton Sat, 06/14/2008 - 15:34
  • Silver, 250 points or more
Hi Craigvoice,
This link will detail what module's are supported in the 6509E.
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps5138/product_data_sheet09186a00800ff916_ps708_Products_Data_Sheet.html
• Content services gateway
• CSM
• Firewall module
• IDS module
• IP Security (IPSec) VPN module
• Network analysis module
• Persistent storage device
• SSL module
• Wireless LAN services module
HTH, Please Vote.
Justin Brenton
Jon Marshall Sun, 06/15/2008 - 13:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Craig
I'm not sure what you mean by 3 different backplane slots, as i am only aware of 2 ie.
1) the classic shared 32Gbps bus
2) The Crossbar switch fabric.
Some modules such as the 10GE modules have 2 connections on them but they are still both connecting into the crossbar fabric.
To answer your question. The Supervisor 720 must go in slot 5 and the redundant supervisor (if you have one) in slot 6. After that with the 6509E you can put your other modules in any available slot.
Some chassis do have limitations such as the 6513 where any module with dual connections, such as the 10GE modules, have to go in slot 9 - 13 because only these slots provide dual connections to the switch fabric. But there are no such limitations with the 6509E.
Jon
