sup720 dual sup native mode
Answered Question
Jun 14th, 2008
Cisco:
We upgraded one of our layer 3 switch.
Dual sup slot 5 and 6. Basically, we upgraded the IOS by copying the IOS to sup-bootflash and changing the boot param. My question is, is there anything special we have to do to get the standby sup or does it sync auto?
thanks so much
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Mon 18-Sep-06 23:59 by tinhuang
Image text-base: 0x40101040, data-base: 0x42D90000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF6, RELEASE SOFTWARE (fc1)
nj02ga03ubr01 uptime is 49 minutes
Time since nj02ga03ubr01 switched to active is 48 minutes
System returned to ROM by power cycle (SP by power on)
System restarted at 20:49:57 EST Sat Jun 14 2008
System image file is "sup-bootflash:s72033-ipservicesk9-mz.122-18.sxf6.bin"
nj02ga03ubr01#show module
Mod Ports Card Type Model Serial No.
1 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL09316QPA
4 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL094448D0
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL09465EGV
6 0 Supervisor-Other Unknown Unknown
Mod MAC addresses Hw Fw Sw Status
Correct Answer by n.nandrekar about 8 years 10 months ago
Hello!
You donot have to do anything else for the standby sup. It should automatically sync and come up in SSO mode.
But the image has to be present in the same flash even on the standby. i.e. when you copy the new image to sup-bootflash/disk0 of the active sup, you also have to copy the same image to the corresponding sup-bootflash/disk0 of the standby too.
"Router# copy sup-bootflash: slavesup-bootflash:"
the "slave" prefix to bootflash/disk etc. will refer to the corrosponding storage on the standby. Remember that all the storages are independent on each of the Sups and when reloading, each SUP loads from its own flash. So the same image has to be present in each of them.
In your case, probably you have not copied the image in the sup bootflash of the standby, and so it might be stuck in rommon> . You could copy the same image to a flash disk (disk0:) in the active and physically insert it in the disk0: slot on the standby. Then you can manually boot that image from the disk0: using the nonactive sup console :
Rommon> boot disk0:
Once the standby boots up, you can then copy the image to the slaveSup-bootflash: so that the sup boots up fine next time.
Hope this helps.
Niranjan
(please rate helpful posts).
Overall Rating: 5 (1 ratings)
Correct Answer
n.nandrekar Sat, 06/14/2008 - 22:16
  • Silver, 250 points or more
Hello!
Rommon> boot disk0:
Hope this helps.
Niranjan
