Restricting calls based on Caller ID
Jun 14th, 2008
I wanted to restrict inbound calls in CCM 5.1 from a specific caller ID (recieved via PSTN), my setup has MGCP gateways with centralised dial plan
any way this can be achieved in on CCM o GWs, i went through certain posts on Internet but no help, looks like this can be done on H.323 Gws but in CCM or MGCP Gws
Chris Deren Sun, 06/15/2008 - 04:52
CM does not natively allow for this, there are several options:
1.use H323 protocol and use reject rules on GWs
2. Use IPCC or Unity which allow for screening calls based on ANI, the downside is that all calls would need to be routed through these apps and port liceses may be an issue.
HTH,
Chris
satish rawat Sun, 06/15/2008 - 15:10
HI
thanks for the response but its seems i cannot access this link withmy level of access, can you please send me this pdf or copy paste how to program this
thanks
