VTP version3 in cisco 3750
Answered Question
Jun 14th, 2008
I have a cisco 3750 switch as the vtp server. At the moment i use vtp version2.
I have a requirement of using vtp version3.but when i type "vtp version ?"
it shows only "1-2". Is vtp version3 not supported in cisco 3750 switch?
Correct Answer by n.nandrekar about 8 years 9 months ago
Yes!
VTP v3 is not supported on 3750. It is only supported on the 7600 SRC & SRC1 releases and Catos releases for c6500/4000.
You can use cisco feature navigator to cross-check.
Niranjan
(please rate helpful posts)
Overall Rating: 5 (1 ratings)
Correct Answer
n.nandrekar Sat, 06/14/2008 - 23:38
  • Silver, 250 points or more
Yes!
Niranjan
Pravin Phadte Sun, 06/15/2008 - 06:27
Its not supported in 3750 switch ios.
