PGW reboot for machine and services ..............?????????????...........
Answered Question
Jun 15th, 2008
any body can tell me how can:
1. Reboot PGW as machine (Totally reboot)
2. Service rebbot only
please can show the commands and steps.
thank you for any help.
Correct Answer by scpage about 9 years 1 month ago
1) /etc/init.d/CiscoMGC stop
reboot
2) /etc/init.d/CiscoMGC stop
/etc/init.d/CiscoMGC start
Overall Rating: 5 (1 ratings)
Correct Answer
scpage Mon, 06/16/2008 - 12:28
  • Cisco Employee,
reboot
tareqrebhi Tue, 06/17/2008 - 01:13
ok thank you.
i have now this issue:
i need to add new E1 to be in the same trunk for previous E1 which is for Abdali. new E1 will not have signal it depeneds at old one timeslot.
i used this for new E1:
prov-add:nailedtrnk:name="1033",srcsvc="ss7p-jtc-abdali",dstsvc="naspath1-abdali",srcspan="ffff",dstspan="0",srctimeslot="33",dsttimeslot="33",spansize=31
for old one this:
prov-add:nailedtrnk:name="1002",srcsvc="ss7p-jtc-abdali",dstsvc="naspath1-abdali",srcspan="ffff",dstspan="0",srctimeslot="2",dsttimeslot="2",spansize=30
at AS5400 i used to add new E1:
controller E1 7/2
framing NO-CRC4
pri-group timeslots 1-31 nfas_d primary nfas_int 1 nfas_group 0
Is this true or there are other commands i should use?
OLD E1 is configured as:
controller E1 7/0
framing NO-CRC4
channel-group 0 timeslots 1
pri-group timeslots 2-31 nfas_d primary nfas_int 0 nfas_group 0
description Connection to Abdali
interface Serial7/0:0
no ip address
encapsulation ss7
channel-id 0
interface Serial7/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-ni2c
isdn incoming-voice modem
isdn map address . plan isdn type network
isdn rlm-group 0
no isdn send-status-enquiry
isdn negotiate-bchan resend-setup
isdn bchan-number-order ascending
no cdp enable
any help please for correct commands i shall use? please see attached file for details
