attaching ipv6 access-list to class-map unsupported ?
Answered Question
Jun 15th, 2008
on router Cisco 7507 IOS 12.2(25)S5
I created an IPv6 access-list already on router called ABC_12.
and When I try to get these commands on router:
rot7507-3(config)#class-map CG_1_name
rot7507-3(config-cmap)#match access-group name ABC_1 <!-- Works -->
rot7507-3(config-cmap)#match access-group name ABC_12 <!- error -->
IPV6 access list is not supported in match commands
and when I try other way around i.e. define class-map followed by
Access-list, it gives
"ACL "ABC_1" is currently attached to classmap, please remove the ACL
from classmap".
Correct Answer by n.nandrekar about 8 years 4 months ago
ABC_1 is still attached to the class map right?
Overall Rating: 4 (1 ratings)
Correct Answer
n.nandrekar Sun, 06/15/2008 - 09:28
tarandeep Sun, 06/15/2008 - 09:46
i think u misunderstood my question, let me re-frame
Initially i created ipv6 accesslist say ABC_12,
then i tried to attach to class-map it failed with error sayin "unsupported"
and wen i tried creating class-map followed by ACL, it gave different error..
> All i wanna know is whether IPv6 acls are supported with class-maps on the router/IOS version i specified.
Thanks in advance..
thotsaphon Sun, 06/15/2008 - 10:32
It should be fine to use IPv6-ACl on the class-map command.Just try to upgrade your cisco IOS.Let's check what features you are looking for here. :
Note: I didn't see your IOS when I used these keywords
- IPv6 QoS: (Quality of Service)
- IPv6 QoS: MQC Packet Classification
