contents of vlan.dat file
Answered Question
Jun 15th, 2008
  • Bronze, 100 points or more
hi everybody
Does any body know how one can view the contents of vlan.dat? is there any command to do that ?
thanks and have a nice day !
Correct Answer by foxbatreco about 8 years 11 months ago
Vlan.dat file is one in which all vlan and vtp related information is stored.
Check n view the contents of this by using:
"more vlan.dat" command.(excluding inverted commas.)
the contents are some strings having vlan names
Pls rate/mark if this helps!!!
Correct Answer by mahmoodmkl about 8 years 11 months ago
I think u can use
switch#more vlan.dat
which might give u some additional input.
Mamood
Overall Rating: 5 (2 ratings)
andrew.butterworth Sun, 06/15/2008 - 12:47
  • Gold, 750 points or more
I don't think there are any IOS commands to 'view' the vlan.dat file, however it is pretty easy to copy it onto a TFTP or FTP server and view it from a PC. It isn't really readable though (I have just tried it with a switch I use at home).
If you just want to view the VLANs on the switch, just use 'show vlan'. This will show you what VLANs are configured on the switch and which ports are in which VLAN.
Andy
Correct Answer
mahmoodmkl Sun, 06/15/2008 - 12:52
I think u can use
Mamood
Correct Answer
foxbatreco Sun, 06/15/2008 - 12:54
