DNS ZONE Config on CSS
Jun 15th, 2008
Hi All,
Is it possible to config DNS ZONE config on CISCO CSS.
Can anyone explain me what does this commands do
dns-server zone 1 tier1 "primary"
dns-server
dns-record a <Zone Name> <External IP> 1 single kal-icmp <VIP> 254 sticky-disabled weightedrr 1
ebreniz Fri, 06/20/2008 - 06:17
How to Configure the CSS to Load Balance DNS Servers
http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_configuration_example09186a00801d015a.shtml
For example,Basically we need to enter the following commands:
Configure the DNS server zone for zone-based DNS. Specify the zone, tier number, and an optional text description:
- CSS (config)# dns-server zone 0 tier1 ""
Configure the CSS to act as a DNS server:
Add the DNS records as needed:
- CSS (config)# dns-record a www.home.com 192.x.1.1 15 single kal-ap 172.x.25.1 50
sticky-enabled
Configure DNS as primary to point to itself:
CSS (config)# dns primary 172.x.1.90
(circuit VLAN1 - ip address 172.3x.1.90 / 24)
This is just an example but it is basically all you need to configure DNS on the box.
DNS configuration commands:
http://www.cisco.com/univercd/cc/td/doc/product/webscale/css/css_710/cmdrefgd/cmdglobc.htm#wp1104782
A different use on the box for DNS would be basically to load balance the DNS traffic
between DNS servers. This is however something different to configure on the box and more
details can be found here:
