CVP Run External Script
Answered Question
Jun 15th, 2008
All,
I have a think a very simple error. I got my SendToVRU Node working great and when I try to use an application on CVP it doesnt work. From a show voip application vmxl all I see this error.
006423: *Jun 16 06:12:25.321: //117//HIFS:/hifs_http_cb: hifs http callback: loa
d of http://10.1.1.26:7000/CVP/en-us/app/Server?application=HelloWorld failed. S
tatus=httpc error 404=http not found
The application is actually at http://10.1.1.26:7000/CVP/Server?application=HelloWorld I have set
user.microapp.media_server to http://10.1.1.26:7000/CVP
and
user.microapp.ToExtVXML[0] to "application=HelloWorld" where is it geting the en-us/app in the path to the VXML Browser? Can someone help me sort the right variable to set? Thanks!
Chad
Correct Answer by geoff@hp.com about 8 years 8 months ago
Chad, do you have the ECC variable user.microapp.UseVXMLParams = "N".
I hear you about the course. Well, you seem to be doing pretty well despite that.
Geoff
Overall Rating: 5 (1 ratings)
geoff@hp.com Mon, 06/16/2008 - 04:04
You need to set another ECC variable to push it up a level. Set "user.microapp.app_media_lib" to "..". This bypasses this ECC variable as well as the locale ECC variable, magically producing what you need.
See CVP 7.0 Guide page 152 and many more.
(PS: have you taken the CVP I course?)
Geoff
Chad Stachowicz Mon, 06/16/2008 - 07:23
Geoff,
I had tried it before with "..." and it didn't do what you said, however with "..". I get this ..
Loading fail with url (http://10.1.1.26:7000/CVP/Server.vxml)
I checked this path and don;t see a Server.vxml. I must be missing something very simple.
About the CVP 1 course, I wish that I had that option but self learning is what I have been diminished too, this seems to be the last thing before scripts are actually playing with correct CVP Call flow, after that I should be fine!
Few more debugs...
name=Server src:
URI(abs):http://10.1.1.26:7000/CVP/en-us/../Server.vxml
scheme=http
host=10.1.1.26
port=7000
path=/CVP/Server.vxml caching=invalid fetchhint=invalid fetchtimeout=-1 maxag
e=-1 maxstale=-1
008576: *Jun 16 14:59:38.859: vxml_param_proc: name=application expr='HelloWorld
' valuetype=115
008577: *Jun 16 14:59:38.863: //-1//VXML:/vxml_play_prompts: Enter
008578: *Jun 16 14:59:38.863: //-1//VXML:/vxml_play_prompts: Exit
008579: *Jun 16 14:59:38.863: //132/AC5FE99C802D/VXML:/vxml_vapp_bgload_from_pro
c:
urlp=http://10.1.1.26:7000/CVP/Server.vxml
008580: *Jun 16 14:59:38.863: //132//AFW_:/vapp_bgload: url=http://10.1.1.26:700
0/CVP/Server.vxml
Chad
Correct Answer
geoff@hp.com Mon, 06/16/2008 - 08:30
Geoff
Chad Stachowicz Mon, 06/16/2008 - 10:41
Geoff,
Thank so much! I finally heard a script in CVP play from correct call flow, and I don't think I've ever been so freaking happy! I am actually familiar with writing the scripts since I had CVP working with CVPSelfService.tcl / .vxml long ago, before I had a valid Call Server License!
Thanks for bearing with me and answering so many of my silly questions, this is a great community and some of us would be so in the dark without the support here! Hopefully soon I can get to a level, where I can start giving back!
Thanks again!!!
Chad
