How to use Offset-List in RIP for Back-up Route?
Jun 15th, 2008
Assalam o Alaikum,
I have a network with redundant links. I want to have one as Primary and the other one as Backup. the configuration is attached with the diagram of network.
Overall Rating: 3 (1 ratings)
royalblues Sun, 06/15/2008 - 23:52
  • Green, 3000 points or more
You need to create an access-list identifying the networks and then offset the metric out of that interface
for eg.
If you want 10.0.0.0/23 to be used as bakup over the VSAT connection, you need to d0 someting like this
access-list 10 permit 10.0.0.0 0.0.1.255
router rip
version 2
offset-list 10 out fastethernet 0/8
http://www.cisco.com/en/US/docs/ios/12_3/iproute/command/reference/ip2_o1g.html#wp1036466
Narayan
royalblues Mon, 06/16/2008 - 02:23
If you choose out, then it should be on the branch switch
If you prefere using IN, then you need to use it on the router interface connecting to the switch
Narayan
