Directories XML
Answered Question
Jun 15th, 2008
i've written an asp script for LDAP directory search and pointed the phones to it. However, when i press the directories button, the new menu entries are not shown.
This is the XML output of the script:
<CiscoIPPhoneMenu>
<Prompt>Izberite imenik</Prompt>
<MenuItem>
<Name>Imenik organizacije</Name>
<URL>http://<server_ip>/IPTServices/LDAPSearch/ldap_welcome.asp</URL>
</MenuItem>
</CiscoIPPhoneMenu>
Where did i mess up?
Correct Answer by pklos about 9 years 1 month ago
you have text/html and you should have text/xml!
Overall Rating: 5 (1 ratings)
markotisler Mon, 06/16/2008 - 03:51
I have restarted the phones and also tried with xml version line, the result is the same. I tried and subscribed this script as a service and accessed it from the phone->services button. What happens is, that i get the same XML output as with a browser on a pc instead of seeing menus.
Marko
pklos Mon, 06/16/2008 - 04:02
  • Silver, 250 points or more
So you need to send http header before xml tags in your asp script.
content-type: text/xml.
regards,
PK
pklos Mon, 06/16/2008 - 04:05
Like this:
<%response.ContentType="text/xml"%>
markotisler Mon, 06/16/2008 - 04:09
I did. This is my asp code:
<%@ Language=JavaScript %>
var serverIP<
serverIP = Request.ServerVariables("LOCAL_ADDR");
Response.ContentType = "text/html";
Izberite imenik
Interni imenik
http://ccm:8080/ccmip/xmldirectory.jsp
Imenik organizacije
<% = serverIP %>/CiscoIPServices/LDAPSearch/ldap_welcome.asp
Cant figure out what's wrong.
Marko
Correct Answer
pklos Mon, 06/16/2008 - 04:17
tomtom001 Fri, 06/20/2008 - 12:52
Can I ask which version of CM you were using? I'm looking to do the same thing for CM 6.1.
Thanks!
markotisler Sat, 06/21/2008 - 07:25
I did this on 6.1 also, although it really doesnt matter which version you are using.
Marko
