CATALYST 6000 - DIFFERENT CONFIG REGISTER ON MSFC2 AND SUPERVISOR
Jun 16th, 2008
This info is from a Catalyst 6000 supervisor 2 WITH Cat6k MSFC2 daughterboard. I have 2 questions.
1. The config-register is 0x2102 on MSFC2 and 0x2021 on the supervisor.
Q: How do I change 0x2021 to 0x2102 ?
2. When I reload the sysstem it starts up from sup-bootflash. show version shows System image file is "bootflash:c6sup22-dsv-mz.121-8a.E5" . I have checked the md5 checksum on the image in slot0 so I know it is OK.
Q: Can the reason for not reloading on slot0 (as the BOOTVAR dictates) be 0x2021 on the supervisor ?
Simon.
gwco1#sh bootvar
BOOT variable = slot0:c6sup22-psv-mz.121-27b.E4.bin,1;sup-bootflash:c6sup22-dsv-mz.121-8a.E5,1
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
gwco1-sp#sh bootvar
BOOT variable = slot0:c6sup22-psv-mz.121-27b.E4.bin,1;bootflash:c6sup22-dsv-mz.121-8a.E5,1
CONFIG_FILE variable =
Configuration register is 0x2021
gwco1#sh slot0
-#- ED --type-- --crc--- -seek-- nlen -length- -----date/time------ name
1 .. image 9D7B9785 18C6F7C 29 25849596 Jun 11 2008 12:58:58 c6sup22-psv-mz.121-27b.E4.bin
gwco1#sh sup-bootflash:
1 .. image 3CDD0DDB 12C0778 24 19138296 Dec 27 2001 06:49:44 c6sup22-dsv-mz.121-8a.E5
gwco1#sh bootflash
1 .. image B597155E 21D670 25 1693168 Dec 27 2001 06:52:04 c6msfc2-boot-mz.121-8a.EX
Overall Rating: 3 (2 ratings)
n.nandrekar Mon, 06/16/2008 - 02:03
hi!
Confreg 0x2101 will boor the image in sys ROM and ignore the boot commands. You can change the confreg for the SP from the ROMMON mode. Reload, issue a break and go to rommon.
then :
rommon 3 > priv
You now have access to the full set of monitor commands.
Warning: some commands will allow you to destroy your
configuration and/or system images and could render
the machine unbootable.
rommon 5 > confreg
Configuration Summary
(Virtual Configuration Register: 0x2)
enabled are:
[ 0 ] break/abort has effect
[ 1 ] console baud: 9600
boot: ...... image specified by the boot system commands or default to: cisco2-Cat6k-Sup32
do you wish to change the configuration? y/n [n]: y
enable "diagnostic mode"? y/n [n]:
enable "use net in IP bcast address"? y/n [n]:
enable "load rom after netboot fails"? y/n [n]:
enable "use all zero broadcast"? y/n [n]:
disable "break/abort has effect"? y/n [n]:
enable "ignore system config info"? y/n [n]:
change console baud rate? y/n [n]:
change the boot characteristics? y/n [n]: y <<<<<<<<<
enter to boot:
0 = ROM Monitor
1 = the boot helper image
2-15 = boot system
[2]: 2 <<<<<<<<<<<<<<
enabled are:
do you wish to change the configuration? y/n [n]: n
rommon 6 > sync
rommon 7 > reset
Resetting .......
=== or ======
rommon 2 > confreg 0x2102
You must reset or power cycle for new config to take effect
Either of these will set the config reg to 0x
Niranjan
(please rate helpful posts)
simonvyrdal Mon, 06/16/2008 - 03:39
I wondered if I had to break to rommon to change the configregister for SP. I understand I have. thanks for the tip to enter 0x2102 directly by rommon 2 > confreg 0x2102. I always used confreg and so on.
apparently it does not matter what the SP config-register is as long as the router config-register is 0x2102. regards Simon
n.nandrekar Mon, 06/16/2008 - 04:12
Hi!
To clarify on the issue, I'll give an instance when I ended up having 2 diff config registers on SP and RP (msfc).
I changed the reg to 0x2142 from the IOS CLI. Then during the reload, I issiued a break to enter rommon and then changed the config reg back to 0x2102. But the image still loaded without the startup and then realized that the confreg @ RP was still the same. So you need to change the config reg directly from IOS to make it reflect on SP as well as the RP.
You can also issue a break after " changing /passing control to the route processor" The rommon that you get now is the RP rommon and not the SP rommon. the change in the config reg here will reflect the confreg of the RP(MSFC).
eg.
*Jun 13 09:40:59.504: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor for this switch
Firmware compiled 06-Jun-08 04:09 by integ Build [100]
*Jun 13 09:41:09.335: %OIR-SP-6-CONSOLE: Changing console ownership to route processor
<<<============= Issue break here=========>>>>
System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2004 by cisco Systems, Inc.
Cat6k-Sup720/RP platform with 1048576 Kbytes of main memory
Download Start
Niranjan
