::: Problems with DPNSS and MG AS5400 :::
Jun 16th, 2008
I am installing a new AS5400 and using DPNSS from the E1 connection.
I am experiencing an error in the MG Debug Q921 such as: PBXa RX <- UNKNOWN dlic=0 . Is this a problem from the SP side? Or MG side?
I have the following:
ISDN Serial6/4:15 interface
dsl 2, interface ISDN Switchtype = primary-dpnss
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = IUA BACKHAUL 0x0002
Layer2 status:
Channel 1 : OUT OF SERVICE
interface Serial6/4:15
no ip address
encapsulation hdlc
isdn switch-type primary-dpnss
isdn bind-l3 iua-backhaul as-mg
isdn dpnss pbxA
no cdp enable
Thank you and best regards,
Bruno Nunes.
smalkeric Fri, 06/20/2008 - 08:12
we need to determine how/why the B-channels are out of service. NFAS B-channels can be taken out of service by the remote end. "Show isdn service detail" might help.
Also, a q.931 debug trace of the dsl after shutting down/no shutdown of the serial interface would show service messages that should bring the B-channels IN_SERVICE.If there is a misconfiguration between the switch and the router (DSL or
nfas_int), the B-channels would not be brought into service by the switch. (The router sends service messages for each B-channel (IN_SERVICE), and places the B-channel in service when/if it receives an IN_SERVICE service
ack from the switch.
